TwinTurbo.NET: Nissan 300ZX forum - Best one I found was related to syncing z1 tb's. Aafter I
treese88
on April 26, 2012 at 9:25 AM
I remember seeing a write-up somewhere IIRC.
posted by rojoloco (VA Beach)
on April 26, 2012 at 07:00 AM
Found it was pretty easy. Try searching "z1 throttle syc" or something like that. The method in the FSM...no thanks.
'91 TT
RPM dip when tapping throttle - only when cold
treese88
12:26:32 04/24/12
I have this same issue.
Draker (Eugene, OR)
12:37:21 04/24/12
When I talked to SZ months ago their guess for a different
treese88
15:25:40 04/24/12
You should check your fuel pressure,
MeatMan - 604Z.ca -
13:10:02 04/24/12
Thats what I thought at first..so I first pressure tested
treese88
15:17:55 04/24/12
what do you consider "significantly"? (n/m)
fuzzymonkey
14:22:07 04/24/12
Significantly is probably not the right word. If I'm idling
treese88
15:21:43 04/24/12
Sounds like an issue with timing. Are your MAF(s), TPS and
Gordo 93TT Daytona
19:52:08 04/24/12
Yep those are all good (they've been swapped). Stock
treese88
20:29:19 04/24/12
I would take another look at the timing as well.
Draker (Eugene, OR)
00:27:43 04/25/12
My cas is 15 dead center :/ darn
treese88
07:40:02 04/25/12
Good luck. Keep us posted. (n/m)
Draker (Eugene, OR)
17:37:10 04/25/12
My CAS is off to one side as well.
rojoloco (VA Beach)
06:59:31 04/26/12
Skipped tooth worst case. Also my timing light would get two
treese88
09:29:17 04/26/12
When it is in the center, it runs for crap.
rojoloco (VA Beach)
10:46:35 04/26/12
On all TT i have owned the cas has never been centered
toykoz32
22:40:18 04/26/12
It was pretty muh dead center on my last motor.
rojoloco (VA Beach)
05:21:00 04/27/12
I had the same problem . . once i sync'd the throttle
toykoz32
01:07:37 04/25/12
rojoloco (VA Beach)
07:00:10 04/26/12
Best one I found was related to syncing z1 tb's. Aafter I -
treese88
09:25:27 04/26/12
Did this yesterday. Good recommendation and helped a little
treese88
09:22:48 04/26/12
Did you also get the slack out of the accelerator cable? (n/m)
toykoz32
16:10:50 04/28/12
It was already properly adjusted, forgot to mention.
treese88
19:35:51 04/28/12
I have the same problem.
rojoloco (VA Beach)
07:04:18 04/26/12
Very similar except I'm rich...and not moneywise!
treese88
09:35:57 04/26/12
I can try it out since it is easy.
rojoloco (VA Beach)
10:49:02 04/26/12
After adjusting the TB'S and then the TPS the dip appears to
treese88
13:47:42 04/30/12
